June 13, 2025, 05:14:20 PM *
Author Topic: "trim code unknown"  (Read 7384 times)
Rabbitoh
FE - 'King of Cars'
« on: June 19, 2007, 09:55:06 AM »
What colour interior trim would have been used on an FE Van painted (Duco Laquer) 'Ocean Mist Green'?
The number on the I.D. plate 157-598(or 596) comes up unknown on the decoder.
R.
Bunnies' 22nd in 2025?
« Reply #1 on: June 19, 2007, 11:06:13 AM »
The code is 598 - Lagoon Green
Regards  Ken
Rabbitoh
FE - 'King of Cars'
« Reply #2 on: June 19, 2007, 11:10:06 AM »
Thanks for that Ken.
The decoder is not infallible Shocked!
Geoff_K
The 2 BAY s
« Reply #3 on: June 19, 2007, 12:08:27 PM »
Hi Rabbitoh,
Lagoon Green PVC trim was only only used on 2 FE van bodies colours:
Ocean Mist Green (157-598) or Levant Green (175-598).
Quite rare, but I know of 2 vans that have/had this trim.
Do you have the rest of the ID & c/n for this van.
Geoff_K
« Last Edit: June 20, 2007, 06:51:54 AM by stinky » Logged
« Reply #4 on: June 20, 2007, 02:45:47 AM »
This is the ID plate for Rabbitoh's new van
FE 2104 853 A
157 598
256 7471
333
chassis number is 8-20923 M
As you suggest ii is Ocean mist green.
Regards   Ken
Rabbitoh
FE - 'King of Cars'
« Reply #5 on: June 20, 2007, 03:04:17 AM »
Thanks for that Ken,
I didn't have all the info. at work with me Wink.
R.
Geoff_K
The 2 BAY s
« Reply #6 on: June 20, 2007, 09:40:52 AM »
Thanks for the ID details.
Very tight set of Ocean Mist Green Van's out of Adelaide, very close together down the production line.  Adds weight to the theory that the factories 'batched' colour and trim combinations.
Geoff_K
Rabbitoh
FE - 'King of Cars'
« Reply #7 on: July 18, 2007, 07:56:04 AM »
Geoff_K,
It appears the subframe was replaced on my van at some stage.
The original chassis number was: 7-26666 M
Manufacture date based on original engine no. was July '57.
Geoff_K
The 2 BAY s
« Reply #8 on: July 18, 2007, 08:58:22 PM »
Hi Rabbitoh,
Thanks for that, confirms closeness with other Ocean Mist Van
Chassis no's 599 apart
Body no's 13
However it does show that 'Chassis' were being built separately and being stacked ready for 'Bodies', and that in this instance they had 'at least' 600 chassis ready because the the 'later van' has the earlier chassis no.
I guess the old store room problem occurred; the older stock being stockpiled and then getting stuck at the back of the rack.
Cheers, Geoff_K
« Reply #9 on: July 19, 2007, 05:14:42 AM »
Dunno about that, Geoff.
Chassis numbers were stamped on the assembly line, not as part of manufacture. All vans were manufactured in Adelaide, these two 13 apart. Both happened to be assembled in Melbourne, 599 vehicles apart. Their sequence out of Adelaide has at best only a rough "batched" correlation with their sequence in Melbourne.
In any case 600 chassis numbers is only a few days' worth of vehicle assembly.
Geoff_K
The 2 BAY s
« Reply #10 on: July 19, 2007, 06:52:11 AM »
Yes you are right RET, chassis were not stacked!
I was not thinking about Adelaide to Melbourne trip.
However, if I run my line of thinking, one of the Adelaide 'Bodies', took longer to get onto the Melbourne Production Line, and thus was 'stacked/parked' somewhere for a longer time.
Figuratively, it either missed the train, or the truck driver went to sleep!
Cheers, Geoff_K
Page created in 0.033 seconds with 20 queries.
