August 06, 2025, 02:59:58 PM *
Author Topic: FC Bits....  (Read 6992 times)
Graeme
« on: June 08, 2007, 10:19:07 AM »
Unfortunately, project not going to be finished in the near future due to work committments so am putting a few bits I can replace later up for grabs:
- Chev Rally Wheels 15 x 7 with corvette caps, HQ and   up stud pattern $750.00
- Stainless Steel 60 litre fuel tank, brand new, never had fuel in it, has return line for EFI if needed. $750.00
- Shortended VL Commodore diff complete with saddles ready to fit to FE/FC $800.00
- Modified VL Commodore radiator - std VL width but has a couple of inches removed from height to fit FE/FC and fitted with a thicker core.  Never used.  $350.00
If anyone interested, pm here as I check in regularly.
Graeme
FATBOY
« Reply #1 on: June 08, 2007, 06:39:34 PM »
Hi graheam could you measure your diff from axle flange to axle flange and let me no the length as i could be interested in it for my ute
cheers fatboy
fatboy
0414712441
Graeme
« Reply #2 on: June 08, 2007, 08:31:04 PM »
Will do over the weekend Fat and pm you the results.
Graeme
TAYZ
« Reply #3 on: June 09, 2007, 10:19:04 AM »
What the ...........  FC is on the road Graeme, Im coming over what night next week suits?Huh??   gotta get the wagon on the road mate!!!!!!!!!!!!!! Shocked Shocked Shocked Shocked
Graeme
« Reply #4 on: June 09, 2007, 10:36:49 AM »
Hey Tayz,
That is bloody good news - well done.
My business is going thru its quiet time and need to fund it for a while so will get rid of some replaceable bits and when things get busy and people start paying I will replace them.
Not selling the body and trim, etc...... might put the motor and box on the market, depends how quick things pick up......
I am home most nites during the week, and will be around all weekend, just give me a yell when you are coming.
Graeme
TAYZ
« Reply #5 on: June 09, 2007, 10:40:05 AM »
No worries mate and fair enough, might be able to throw a bit yr way hopefully, I will give you a call, cheers
        tayz
brett_f
« Reply #6 on: June 11, 2007, 04:38:46 AM »
What is the measurements of the radiator ? Has it side tanks or above / below tanks and was it set up for a holden v8. regards brett
Graeme
« Reply #7 on: June 11, 2007, 05:58:17 AM »
Fatboy:
The diff is 1380 outer drum face to outer face drum, give or take a mill or two.  Diff is installed in my fc with rear leaf springs in their standard position.  It was setup to run the 15 x 7 chev rally wheels with 215/70 tyres with good clearance.
Brett:
The radiator is approx 665 wide by 415 high.  It is essentially a standard VL Commodore radiator with a couple of inches taken out of the height so it would fit height wise into the fc radiator hole (widended to suit). It has a thicker core fitted to compensate for the reduced height.  Tanks are on the sides, NOT top and bottom. The car is not a V8 but running a VL Commodore 6 and auto.
Graeme
« Last Edit: June 11, 2007, 05:59:32 AM by gjs » Logged
FATBOY
« Reply #8 on: June 11, 2007, 11:47:19 AM »
Hi Graeme thanks for the measurement just wondering if you could get back under the car and measure the diff from  the end of the housing where it has 4 bolt holes to the other side . Do you no what ratio is in it because ive got a 4 pinion centre at home to go into one
cheers fatboy
ps could you send me some pics of your radiator
cheers fatboy
fatboy
0414712441
Graeme
« Reply #9 on: June 12, 2007, 02:03:15 AM »
Hey Fat,
Got under again and the best i could measure was 1230 end to end.  Again, that may be give or take a mil or two.
I have some photo's of the radiator I can email to you - what is your email address....
Graeme
brett_f
« Reply #10 on: June 12, 2007, 02:14:41 AM »
Grame could you also email me photos of radiator. regards brett
forensic.lock@optusnet.com.au
FATBOY
« Reply #11 on: June 12, 2007, 04:16:16 AM »
fat8oy@hotkey.net.au is my email your diff measures the same as my vl diffwhat part of vic are you in
cheers fat
fatboy
0414712441
ipg
« Reply #12 on: July 09, 2007, 08:37:43 AM »
hi graeme, i have sent you an email.
patrick
Graeme
« Reply #13 on: July 14, 2007, 10:39:14 AM »
G'day one and all,
parts now withdrawn from sale.......
thanks for your interest.
Graeme
