September 06, 2025, 07:24:23 AM *
Author Topic: hr drum front end.  (Read 2597 times)
Just40
« on: May 11, 2007, 06:16:13 AM »
ok i know bugger all about front ends,but i have got a hr drum front end here can i put uc torana disks straight onto it.
Burnsy
« Reply #1 on: May 11, 2007, 09:00:06 AM »
Pretty sure you will need to change the spindles to disk ones first.
Mike
cruiser056
cruisin to the rock and roll
« Reply #2 on: May 11, 2007, 05:45:35 PM »
John,
        You will have to put the other hubs on first.
Michael
Rob_FE_56
« Reply #3 on: May 11, 2007, 09:46:43 PM »
 G'day John,
The torana disks will go on the hr drum brake stubs but you will need to make some adaptor plates to bolt your calipers on with.  Obviously you will need to fit an FE-EH outrigger to your hr crossmember.
It works ok but if you can find some disk brake stubs you will end up with a neater conversion.
Another thing to consider is that the LH-UC torana disks will widen your track by close to an inch on either side and causes guard clearance issues on lowered cars with wide (6"+) rims.
If I was going to put disks on an original grey powered car I would put new replacement hr disks on the kingpin front end with adaptors for the calipers.
The kingpin front ends drive pretty good.
Cheers, Rob.
