August 21, 2025, 06:02:35 PM *
Author Topic: Trimatic detent cable?  Help?  (Read 2934 times)
Damon
« on: September 26, 2002, 09:28:13 AM »
I was wondering if some of you guys running red motors and trimatics could share  a little info on your detent setup?
I have got the accelerator and gear change sorted out nicely but don't have enough room on the firewall for the original cable HG set up that I had planned to use.
The accelerator set up that I have is a similar type to the original, (bent rod).
My engine/ auto set up came from an '71 HG.
I have been told that I could use an early commodore auto which apparently have an electric kickdown switch under the accelerator pedal?
Has anyone done this, and from what model commodore?
I would appreciate any comments from anyone with a cable or electric kickdown set up, as this is the last hurdle that i have before painting, (I hope)!
:-/Thanks, Damon :-/
« Reply #1 on: September 26, 2002, 11:31:28 AM »
 ;)Hi Damon
  Early model commodore trimatics have the selector shaft coming out of the left hand side and HG trimatics right hand side.
  I have used a HQ-HZ trimatic with the accelerator and electric kickdown switch assembly.
  Hope this helps
  Regards ACE Cool
« Last Edit: September 26, 2002, 11:41:42 AM by ACE » Logged
Damon
« Reply #2 on: September 26, 2002, 11:50:18 AM »
Thanks ACE,
Does your selector sit on the drivers side or the passengers side?
I am assuming that the HQ-HZ trimatic is the same phisical size? I currently don't have a lot of room between the modified tunnel and the HG unit.  Also do you know if the yolk is the same size/spline?
Thanks Damon.
