September 06, 2025, 08:56:25 PM *
Author Topic: uc torana front end  (Read 2404 times)
Just40
« on: January 29, 2007, 01:00:59 AM »
will a uc torana front end fit straight onto an fc......
brett_f
« Reply #1 on: January 29, 2007, 01:47:37 AM »
currently doing this conversion and the answer is no. There is a fair bit of modification to do but will be well worth it as my step brother has been doing this on early model holdens for some time and they drive excellent with full turning. Regards brett
Just40
« Reply #2 on: January 29, 2007, 01:54:59 AM »
what conversion have to be done?
brett_f
« Reply #3 on: January 29, 2007, 02:23:57 AM »
As i said i am still in the process but the original chassis mounts have to be cut to allow the front end to fit between the rails and the original chassis mounts from the fc front end need to be removed and refitted onto the torana front end. Chassis rails then need to be installed to the lower rear supports of the torana front end. Then comes which brakes and stubb axles to use to suit the wheel combination. Hope this helps. regards Brett
