September 06, 2025, 11:38:51 PM *
Author Topic: generator  (Read 4673 times)
« on: January 22, 2007, 08:24:50 PM »
My generator is cactus. Checked it for charge and its not producing a dam thing. Any ideas on how to fix or Is it cheaper to rebuild or convert to alternator?
Just40
« Reply #1 on: January 22, 2007, 10:11:07 PM »
i swapped my two over to alternator so if you need a generator i have some here you can have for free.
« Reply #2 on: January 23, 2007, 06:57:39 AM »
cheers mate, how hard was the alt conversion?
« Reply #3 on: January 24, 2007, 08:57:33 AM »
you home sat?
TAYZ
« Reply #4 on: January 24, 2007, 09:10:31 AM »
I changed mine over to an alternator and it was a very simple conversion
« Reply #5 on: January 24, 2007, 09:13:59 AM »
different brackets needed? same belt?
« Reply #6 on: January 27, 2007, 10:49:12 AM »
Nes, different bracket needed, you will probably need a different belt, but depending on brackets used it may be OK.
Original regulator has to be deleted from the wiring and depends whether you use an Alt within internal or external Regulator as to how the wiring is redone.
Just40
« Reply #7 on: January 28, 2007, 05:42:26 AM »
sorry nes just caught your post,i used an alternator with a built in regulator and made up a bracket to bolt it on.
TAYZ
« Reply #8 on: January 28, 2007, 12:27:01 PM »
Sorry nes also just caught yr post, I did the same as 40, cheers
                                                        tayz, I will try and get a few pics.... but dont hold yr breath
« Reply #9 on: January 29, 2007, 12:11:00 AM »
cheers mate
Page created in 0.04 seconds with 17 queries.
