September 06, 2025, 07:25:21 AM *
Author Topic: HR R&P Front End  (Read 4497 times)
sgo
« on: January 14, 2007, 12:44:48 AM »
$400.  Pick up Jan Juc. Vic.
HR Front-end with Commodore R&P steering.
Has got:
Excellent turning lock.
Very low km ball joints and bushes.
V6 engine mounts-easily removed if not req'd.
Reinforced bottom plate.
Intermediate steering shaft.
HQ stub axles.- suit commodore or hq discs.
Assistance with details for engineering, and installation provided if required.
Needs:
Some ball joint rubber boots replacing.
Front outrigger to suit your application.
Some welding completed.
Early Torana steering arms-modified taper.
Small spacers machined.
Has been removed from vehicle after doing low kms.
Also available one stock HR drum brake front-end, as removed from original vehicle, assume needs complete rebuild?
$250.
minifcvan
« Reply #1 on: January 14, 2007, 12:55:04 AM »
THAT IS SO CHEAP......................................
sgo
« Reply #2 on: January 14, 2007, 01:14:20 AM »
I will accept higher offers Smiley
also contact can be made at:
sgomachen (at) hotmail (dot) com
sgo
« Reply #3 on: January 22, 2007, 09:51:05 AM »
in response to questions:
I have spent some time sorting out a power steering set-up and that's is the reason for removing the manual front-end.
I have adjusted the position of the rack mounts to minimize bump-steer and have the mounts tacked in the correct position so the welds need to be completed.
The steering arms are in use on my current front -end. There may be a tie-rod end that suits the Torana arms needed, or othewise the taper will need to be reamed out to suit the the holden tie-rods as I currently use.
The v6 uses the stock oil filter.
It was in my FC that can be seen in the forum pics section as 59v6
The stubs are bare and you will need either HQ or  VPCommodore discs for whichever stud pattern you want to use.
I'm also currently using the top wishbones so the ones supplied do not have new bushes etc.
sgo
« Reply #4 on: January 30, 2007, 10:38:53 AM »
R&P front end sold.
Still available one stock HR drum brake front-end, as removed from original vehicle, assume needs complete rebuild?
$250.
Russ
mmm dohnuts
« Reply #5 on: March 04, 2007, 08:51:08 PM »
 :-/will the mounts fit the ecotec v6??? and will vt disks fit???
Oh and where in this wide brown land are you??? can you deliver for that price (about 3000km north of adelaide) Grin Grin
Russ
mmm dohnuts
« Reply #6 on: March 04, 2007, 08:53:43 PM »
sold sorry didn't read propa
Page created in 0.048 seconds with 16 queries.
