August 25, 2025, 02:46:11 PM *
Author Topic: Oil Filter Connection to Grey Motor  (Read 3260 times)
graham_fuller
« on: September 14, 2002, 04:41:56 AM »
Where does the side pipe get connected as I can't fit it to the oil pressure switch point as I have a Wilsonia fitted there as well? Any clues.
Thanks, Graham
EJ_Dave
« Reply #1 on: September 14, 2002, 05:53:56 AM »
Graham,
at the oil pressure sender is the right place to connect. The only solution I can think of is to get another T piece.
David
FE_225
« Reply #2 on: September 14, 2002, 10:40:42 AM »
Hi Graham
You can get an adaptor for this. It screws into the oil pressure switch hole and you connect the Wilsonia to the end of the adaptor and the filter hose screws into the side of it. You should be able to get it from Repco.
Hope this helps.
Tony
« Reply #3 on: September 14, 2002, 11:26:35 AM »
Graham, I've got one of these special T pieces.  It has 3 holes oin it - 1 for the oil sender, one for the Wilsonia and one for the filter.  If you have trouble getting one give me a call.
