August 27, 2025, 02:00:21 AM *
Author Topic: How do you remove internal door handles  (Read 3879 times)
ASUS
FC Fun
« on: December 22, 2006, 09:19:23 AM »
Hi,
Seems like a real dumb question I have tried to remove the internal door handle and window winders on the FC.  I can find the circlip, and cant get them off.
Any tricks, I've tried screw driver, Ive tried using a wragg but just can get them off Doesnt help the trim is quite padded.
any help to get these handles of would be appreciated.  Cant get my window up.
« Reply #1 on: December 22, 2006, 09:27:02 AM »
Use the proper removal tool - you can get one from Supercheap or Repco or Bursons. Most places have them and they are quite cheap.
I know what you mean when you have trouble because of the deep padding, but you just have to compress it as best you can as you push the clip with the tool
minifcvan
« Reply #2 on: December 22, 2006, 09:27:06 AM »
hi mate go to repco and buy the tool its about 10.00 and put the tool donw the same way the handle goe's (the lever) and it will pop straight out..cheers mark
ASUS
FC Fun
« Reply #3 on: December 22, 2006, 09:38:04 AM »
Thanks Gents,
I'm sure this will save me a lot of frustration.
Merry Xmas and a Happy New Year.
greyone
« Reply #4 on: December 22, 2006, 10:16:05 AM »
if you look in your workshop manual its got all the dimensions to make your own ,cheaper again
regards mal
« Reply #5 on: December 24, 2006, 06:51:51 AM »
Here's what the tool looks like:
And for $10, I wouldn't advocate bothering trying to make your own.  I inherited a home-made job with my first FC, and it was useless.  The proper ones are made of decent steel that's thin, but doesn't flare at the ends.
Once you get the tines in between the washer and the handle, give it a slight twist  and you'll be able to see the circlip.  More than once I've discovered one that had been fitted back-to-front this way.
Another tip: cover the right-angled end with electrical tape: it's awfully easy to scratch paint with...
[edit: better pic]
« Last Edit: December 24, 2006, 07:00:59 AM by ret » Logged
HAD 708
« Reply #6 on: December 24, 2006, 08:45:10 AM »
Scratch paint and rip vinyl door trims!!!!!! Best 10.00 you will ever spend!
« Last Edit: December 24, 2006, 08:45:40 AM by Brett_Gillard » Logged
Brett Gillard
ASUS
FC Fun
« Reply #7 on: January 02, 2007, 10:01:56 AM »
hi,  got the tool from rare, all good cost me a fiver,
I also got given a tool with a clip remover one end, and a hook scrapper and other stuff, would love to show you but don't know how to add the picture.  Interesting tool
