September 09, 2025, 04:05:48 PM *
Author Topic: Floor pan  (Read 6514 times)
corm
« on: December 02, 2006, 10:31:39 PM »
wondering if anybody has a genuine passenger side front floor pan forsale, also still after a really good dent free front guard spear FC(passenger side),located in Canberra thanks. Wayne.
« Last Edit: December 02, 2006, 10:36:34 PM by stinky » Logged
Johns
Model: something else...
« Reply #1 on: December 02, 2006, 11:11:15 PM »
Hi Corm,
AFAIK NOS front pan sections came in short and full sections. The short ones extend as far as the set of full length strangethening ribs. If you have a look at the one we fitted to the NSF of Nev, that is an uncut section, here;
http://www.fefcholden.org.au/cgi-bin/yabb/YaBB.cgi?board=album;action=display;num=1163736355
So if your front floor isn't too bad you could get away with a short section. If you can, the Rares pans aren't too bad for this. The NOS are much better if you need a full pan.
By the way if your rear floor is rusted up the tunnel sides and towards the front of the rear seat mount, a NOS section is not large enough, but the Rares ones are.
Hope this helps
Brad
« Reply #2 on: December 02, 2006, 11:46:49 PM »
 Hi John
           Where can I buy  2 x NOS  full floor pans for my van. It's had rare's fitted about 18 years ago but I'm not happy with the finish and I'm thinking about replacing them. If I can get NOS I would definitely replace them. I'm in Brisbane.
      Brad.
« Last Edit: December 03, 2006, 12:01:44 AM by BRAD » Logged
corm
« Reply #3 on: December 03, 2006, 01:48:48 AM »
John,
thanks for that mate, I'll need the full section worst luck and i would prefer genuine if possible thanks again.
wayne.
Johns
« Reply #4 on: December 06, 2006, 05:19:39 AM »
Hi Wayne and Brad.
Unfortunately you can't readily get NOS pans. You could post a wanted for them.
We have had to put a rares OSF pan in Nev, thought it was NOS but it wasn't !@#$, should have checked more carefully.
We will be welding this in this weekend. I will then detail the massaging required. The biggest problem with them is not fitting them, it's that the ribs are not as crisp as the factory ones.
Stay tuned
« Reply #5 on: December 08, 2006, 08:30:13 AM »
AFAIK there are no NOS floor pans around, In 30 years of looking at parts - I have never seen one.  I did see an entire front floor once which has a part number, but never a floor pan. What you need to remeber is that FC floor pans have been rusting since the 60's and a number of aftermarket companies made them over the years including R/S who have been making them for at least 20 years as well.  Over this time there have been many different styles and thicknesses and lengths and pressings - some good and some bad.
I would think apart from a few VERY RARE examples of genuine GMH stock - these would have dried up in the late 70's. Look for quality, not necessarily age!
Johns
« Reply #6 on: December 09, 2006, 08:05:07 PM »
Ken, the yellow coloured sections I fitted to Nev came from the NOS warehouse.
Given that the guys have a shed full of new factory panels and that  they match the existing floors perfectly, have a lip which matches the inner sill perfectly and the ribs stampings are identical with the existing floors. I reckon its a fair call that they are factory.
If they're not, they're the best repo panels I've ever seen.
Brad
« Reply #7 on: December 09, 2006, 11:15:49 PM »
Okay
          So where is this NOS warehouse and how do I get in contact with them to see if they have pans for my van.
                      Brad.
« Reply #8 on: December 10, 2006, 05:44:24 AM »
Absolutely Nev, if they came from there then there is a every chance they are GMH items.  I never saw any of the stuff from the warehouse.
Press marks are the biggest giveaway since only GMH presses gave the same exact shape as the original floor.
Also not a single repro floor pan had the drain holes in them.  I assume yours had the drain holes?
« Reply #9 on: December 10, 2006, 11:02:12 AM »
Hey guys.
In my opinion, the yellow/green rust repair sections were made by B & S.
B & S = Barber and Sons. They were located in Alexandria, and stopped making patch panels about 20 years ago. They also made headlight peaks and lower guard sections. It was quality stuff.
I believe not everything from the NOS guys is NOS. These guys bought a collection of FC parts from a guy who bought up everything he could find for FC. Most was NOS, some was good secondhand and some was early repro.
Johns
« Reply #10 on: December 12, 2006, 10:40:13 PM »
Thanks Ken and Alex.
Ken, they don't have drain holes and given Alex's advice, it appears they aren't genuine. As Alex states, they are of excellent quality.
Brad, I don't think the guys at NOS have any more left, I think I got the last ones Wink
Thanks for the heads up guys Smiley
Brad
« Reply #11 on: December 13, 2006, 09:01:56 AM »
Thanks John
                   If you or anyone else has the contact phone number for the NOS warehouse I would really appreciate it so I could check for myself. As I said , mine are a sad reproduction  and the pressed lines don't match very well at all.
     Thanks Brad.
« Reply #12 on: December 14, 2006, 12:26:36 AM »
Do a search for "NOS warehouse", the phone number(s) have been posted quite a few times.
There's a thread in the General Board called "NOS Warehouse", for example.
