September 09, 2025, 10:49:41 PM *
Author Topic: FC/FE front cross member  (Read 3954 times)
brett_f
« on: November 30, 2006, 03:38:57 AM »
Wanted bare front cross member any condition. Need it for the mounting plates only as i am doing a conversion. I am located in melbourne so local would be good
Regards Brett
trevwood
« Reply #1 on: November 30, 2006, 06:02:19 AM »
would an fb one do?
« Reply #2 on: November 30, 2006, 06:50:07 AM »
there are no engine mounts on the cross, there is one on the outrigger, is that the one you want
brett_f
« Reply #3 on: November 30, 2006, 07:52:25 AM »
Thanks guys for your replies. As for the FB cross member i am not sure if the mounting brackets are either the same or same positions as the FC FE. Can anyone verify this. The crossmember i am after is the main one where engine mounts normally go on red motor vehicles. In other words the member that holds the upper and lower wish bones.Regards Brett
« Reply #4 on: November 30, 2006, 11:07:31 AM »
Brett, if it is just the mounting plates you need then a FB one will be fine as the mounts are the same as FC.  In fact the mounts are the same from FE right up to HR.  However the crossmember is a different shape from FB onwards so would be no good if you want to use part of the crossmember for your setup.
brett_f
« Reply #5 on: December 01, 2006, 05:05:10 AM »
Thanks ken your full of knowledge.Therefore i am now looking for a bare cross member from FB to HR as i only want the mounting plates.These are being transfered to a torana front end as my original front end had been reconditioned and it would be ashame to cut this one up.
Regards brett
By the way Ken i haven't forgot about the trims its been because i have been interstate.Will call you soon.
trevwood
« Reply #6 on: December 02, 2006, 05:42:47 AM »
In that case I have an fb one if you want, and Im in melbourne! Call me on 0414 557 622 thanks Trev.
brett_f
« Reply #7 on: December 14, 2006, 10:42:20 AM »
Thanks guys for your help. i have recieved a donor cross member from trev. i have also had my commodore rear end with trailing arms fitted to my fc and looks fantastic. any questions i would be more than happy to answer. Trev has also sighted this conversion.
