August 17, 2025, 09:27:36 AM *
Author Topic: problems with 138  (Read 4131 times)
willmoo
« on: November 24, 2006, 01:19:40 AM »
chasing a set of lifters for a 138 any ideas Huh
Brad
« Reply #1 on: November 24, 2006, 08:51:52 AM »
Hello willmoo.
  Solids or hydraulic?
  Brad
suziecreamcheese
« Reply #2 on: November 24, 2006, 01:52:32 PM »
um arent they all solid??  :Pcant machine em??
willmoo
« Reply #3 on: November 24, 2006, 11:42:51 PM »
yep solids have found six newbies have taken the old ones in to see if there is enough left to be machined.
wait and see whaty they say.
can get some made but they what $47 pop Huh
Brad
« Reply #4 on: November 25, 2006, 08:50:23 AM »
Hey willmoo
                 If you want the motor to rev hard then solids are the way to go as they will not blow out like hydraulic's, which are standard on a grey. Under high revs / pressure the standard oil pump often can't keep up and the lifters fail . instead of having 12 thou on your exhaust you could end up with maybe 25 thou ,not good. Burnt valves etc.
Hydro lifters, if a little bit worn on top can be machined flat as the oil will take up the difference.
  The downside of solids is that they need to be reset often , every couple of hundred miles to keep the tolerances right.
   If you have an everyday driver I'd suggest getting your hydro lifters machined and reconditioned. Any reputable engine recon shop should be able to help you out with this
      Brad.
« Reply #5 on: November 25, 2006, 10:02:28 AM »
Brad, all greys have solid lifters, red motors have hydraulic lifters.
Brad
« Reply #6 on: November 25, 2006, 09:57:35 PM »
       Ooop's,   You are 100% correct. Thanks for pointing that out.
              Brad.
Page created in 0.024 seconds with 18 queries.
