June 07, 2025, 12:45:57 AM *
Author Topic: wiper motor wire  (Read 2393 times)
« on: November 15, 2006, 02:00:58 AM »
Wheres the best place to adapt an EK 2 speed wiper motor to FC wire loom, off accessories or off light switch or other?
« Reply #1 on: November 15, 2006, 06:05:03 AM »
take it off your least loaded circuit NEs, and probably a good idea not to piggybck the circuit.
lights would have high draw i would bet.
giving it a separate fuse would be the best.
« Reply #2 on: November 16, 2006, 08:04:23 AM »
The main wire to the dash from the battery goes to the BAT post on the back of the ignition and from there to the top bar on the light switch.  This bar has three positions for adding live wire feeds and is generally used for running accessories (for example the Air Chief radio is attached here).  You should use a fuse.
If you require a switched live then you need to take the feed from the IGN pole on the back of the ignition switch and this is best done by installing a simple fuse panel and running a single lead to the fuse panel and feeding from there.
« Reply #3 on: November 16, 2006, 11:19:11 AM »
cheers Ken, light switch it is
