paddyfc58
Offline
I wanna go fast
« on: October 12, 2006, 07:46:34 AM » |
could someone tell me where i can send my steering wheel to repair cracks and restore it and how much it might cost to do. i live in north qld.
thanks paddy
TAYZ
« Reply #1 on: October 12, 2006, 08:52:44 AM » |
paddyfc58
Offline
I wanna go fast
« Reply #2 on: October 13, 2006, 10:49:20 AM » |
ta
paddy
GMB-58FC
Offline
Stage one complete...
« Reply #3 on: October 04, 2007, 12:39:39 PM » |
Sorry to drag up an old thread but i figured they had already been mentioned  Has anyone used these guys at all for repairs or can you recommend someone that can touch up my steering wheel for the FC??? Cheers Ben
ABS Hobart- 6231 5855
PM FOR QUOTE
fe1957
Offline
Turbo Charged
« Reply #4 on: October 04, 2007, 08:49:05 PM » |
Why not give it a go yourself, I started with a poor condition wheel, (I should have taken pics) A few hours cleaning out the cracks, sanding it back and 2pac paint it looks fantastic. Easy really. cheers Grant
OFE570
TTV6FC
« Reply #5 on: October 04, 2007, 08:53:38 PM » |
Hey Grant,what did you use to fill the cracks?Does bog work or does it move around too much?I have been considering giving this a go as I have a few very average wheels and thought it would be worth a try.What about paintable/sandable silicons?.Cheers,Jamie.
fe1957
Offline
Turbo Charged
« Reply #6 on: October 04, 2007, 09:07:39 PM » |
Hey Jamie, thanks for pointing that out I forgot to mention , I used a two pack resin, lock tight brand, they all smell like araldite though, it sanded easy, you can then use a light filler etc to smooth. It seemed to paint fine, I suppose time will tell if it lasts, the car won't be out in the sun much though  cheers Grant
OFE570
GMB-58FC
Offline
« Reply #7 on: October 05, 2007, 11:03:33 AM » |
Hi Grant i was going to have ago at repairing it myself but after talking to a few people they were all of the same opinion that i couldn't use normal automotive bog on the wheel nor could they really suggest anything 100% that would be suitable. I have emailed/phoned a couple of places they do this and none of them were all that keen to point me in the right direction (i can understand as that is the basis of their business) but to not even throw a guy a hint i thought was a little rough... I will give it a crack and try and find some of the lock tight resin that you used and see how i go. Any chance you wanted to post a quick DIY of what you did with yours  Cheers Ben
PM FOR QUOTE
Rusty_T
Offline
« Reply #8 on: October 05, 2007, 03:22:00 PM » |
 Paddy I gave it a go with the steering wheel from my Blue car and it came up very well. I have a series of photos .I'll send them if you wish.It's not hard. Cheers Rusty
jack_fc
Offline
SouthWest Coast, Victoria
« Reply #9 on: October 05, 2007, 05:38:28 PM » |
rusty, could you put the photos on here, and tell us how you did it ?? I reckon more than a few of us would be real interested cheers jack
TTV6FC
« Reply #10 on: October 05, 2007, 06:13:17 PM » |
Ditto Jack...
KFH
Offline
« Reply #11 on: October 05, 2007, 08:01:07 PM » |
Ditto also
paddyfc58
Offline
I wanna go fast
« Reply #12 on: October 05, 2007, 09:01:42 PM » |
hi, if you check the latest Just Parts guy has fe-fc steering wheel restored as new changeover $120 ph03 52430498
paddy
fe1957
Offline
Turbo Charged
« Reply #13 on: October 05, 2007, 09:10:09 PM » |
paddy
That is cheap, but honestly there is nothing to it, get an air blower, clean out the cracks (someone decided silicon would be good to use on mine which was a pain) , I spent a few minutes a day putting several coats of resin over the cracks (I even had a whole piece around the centre come off  ) Let it harden for a week, spend an hour or so sanding , and its ready to paint. Grant
OFE570
BAZZA
Offline
« Reply #14 on: October 07, 2007, 05:32:42 PM » |
I did mine with araldite and it was pretty badly cracked. It took a lot of filling but came up great with a bit of filing and then some sanding. I then had it painted in two pack white and it looks real cool. Bazza
Rusty_T
Offline
« Reply #15 on: October 08, 2007, 09:50:48 AM » |
 Hi all, Firstly I'm not to good at uploading multiple pics. Anyway, My steering wheel wasn't in very good condition to start with. This is what I did, . I took a hacksaw and cut each crack.This made the cracks slightly larger but a lot easier to clean out and gave each one straight edges. . Next I cleared them with a blast or 3 of air from the compressor. . Then I mixed a batch of "Septone" Body filler and filled each crack. Sanded the whole wheel and applied a coat of Etch Primmer and a couple of coats of Surface primmer. . The Car is Lark Spur Blue with Silver Flake so I took the paint numbers to "Out West Auto" Paint suppliers Penrith and they mixed the paint in pressure pack . . I applied the paint to the wheel until it ran out and the result speaks for itself. . One point though. I removed the metal ring from the under side of the wheel to clean and paint it.If you do that as well make sure you replace it before you fill any defects . This ring is a press fit and it expands the wheel and it will crack the wheel. I hope this makes sense. Her come the pics I hope.
Rusty_T
Offline
« Reply #16 on: October 08, 2007, 09:53:18 AM » |
Rusty_T
Offline
« Reply #17 on: October 08, 2007, 09:57:10 AM » |
Offline
« Reply #18 on: October 08, 2007, 11:35:15 AM » |
Looks good Rusty. I think the body filler will crack with flex and sun. (I hope I am wrong!!) I picked up a wheel the other day that needs lots of work. It is missing the metal ring from inside the hub though......anyone have a spare before I start repairs? I plan on doing the same, but with Araldite, or maybe 'JB Weld'. Regards Alex
Offline
« Reply #19 on: October 08, 2007, 06:45:47 PM » |
What is wrong with "NEAD IT" to do the repairs, it sticks to any thing and is very strong and does not shrink.I have used nicki many years ago to repair steering wheels and it did not last. I have been panel beating for 35 years FC427
