August 03, 2025, 04:11:12 PM *
Author Topic: drum brake query  (Read 2173 times)
Rabbitoh
FE - 'King of Cars'
« on: October 11, 2006, 08:51:17 PM »
Have noticed the wheel cylinder adjusting cap on my LF wheel extends out quite a bit more on one side than the other.  1. Is this a problem? 2. Can I just open the bleeder and squeeze it back in to match the "good"side (and adjust the brake shoe clearance to take up the slack)?
My concern is it might 'pop off' under heavy braking.
R.
Bunnies' 22nd in 2026?
« Reply #1 on: October 12, 2006, 08:16:24 AM »
Assuming the brake shoes are worn the same (ie the same thickness of lining front and rear) then the brake shoes should be equi spaced in the centre of the brake drums.
Just wind one out the same turns as you wind the other one in as a start then adjust the shoes in the normal fashion.   If one shoe is more worn than the other then you would expect that one adjuster would be wound further out than the other one.
Regards  Ken
Rabbitoh
FE - 'King of Cars'
« Reply #2 on: October 12, 2006, 09:01:23 PM »
Thanks Ken.
The linings appear to be the same thickness (about 3mm- is this thick enough?). I have tried squeezing the offending adjusting cap back onto the cylinder (it looks close to falling off to me), but it won't budge. Do I need to open the bleeder valve to do this? I have also noticed this wheel seems to drag a bit after braking ie. shoes are not returning immediately after release of brake pedal.
Chris
graham_fuller
« Reply #3 on: October 12, 2006, 10:35:55 PM »
Hi Chris,
Sounds like the cylinder is Gummed up and needs to be cleaned out. You will probably find this piston never moves.
Graham
Rabbitoh
FE - 'King of Cars'
« Reply #4 on: October 12, 2006, 10:47:22 PM »
Tah for the input Graham,
Will do on the cleanout.
Chris
Page created in 0.024 seconds with 17 queries.
