August 02, 2025, 07:21:43 PM *
Author Topic: question for ken re brakes  (Read 2136 times)
v8 wagon
« on: October 10, 2006, 07:42:01 AM »
I want to change the stud pattern on the front of wagon to match the rear.
at present it is running vn stud pattern at rear and wb on the front .  (crs hr front end, vn diff at rear).
and it is running hq gts rims front and rear.
can I fit a commodore disc on the front end using the exsisting calliper, or am I better to get a blank wb disc redrilled to commodore stud pattern.( if so how much).
Then I will be fitting commodore rims allround.
steve
« Reply #1 on: October 10, 2006, 08:58:42 AM »
No you cant fit Commodore rotors with HQ to WB calipers.  We can supply HQ rotors in Commodore pattern (about $200 each in smooth- more expensive if slotted or drilled & slotted)
Or P76 rotors in Commodore pattern (once again about $200 each plus bearing fitting kit $140)  The benefit of P76 is that it moves the track in about 18 mm per side.
blacky
« Reply #2 on: October 10, 2006, 08:31:20 PM »
 What I did with my EK was offset drill the existing holes (you need to do this on a mill ) and fit oversize wheel studs. They are still 7/16 thread but the splined bit is larger. The difference in the stud pattern is only 1.6mm or thereabouts.
I bought the studs from Coventrys.
