2 Speed Wiper- HB Torana Wiring Diagram needed.
Started by Rod Mathews, April 22, 2001, 12:00:00 PM
Rod Mathews
I am in the process of converting the vacuum unit to electric. I have purchased an EK wiper motor, switch and base plate. The problem is that the unit is only single speed. So I acquired a 2 speed preslite motor out of a HB torana. It lines up with the holes on the base plate exactly except I had to drill another hole (there was a spot on the plate to do this)to support the motor. I have dismantled the EK switch and have made the necessary modifications to make it two speed. The problem I have at the moment is I have not got a wiring diagram for a HB torana. The motor has a Blue, Red and Black wire. Has anyone got a wiring diagram I can use. Thanks in anticipation. Rod
David Rayment
David.Rayment@ot.com.au   can send you details of motor.  I have a hb and 5 different books.
