HR front ends
Started by jasonr70002, June 22, 2009, 06:44:45 PM
jasonr70002
What difference if any aside from the stub axles is there between a hr disc and drum front end.
cheers Jason
Golden Holdens FE-FC
2door350
nothing...you can use either i'm pretty sure
No difference whatsoever - the drum front end even has the cut outs in the tower for the calipers
jasonr70002
Thanks guys and can I assume that Torana or HQ stubs will bolt straight on as well.
They will... Torana have a few more degree in the stub than HQ -WB  but a lot run them so wheel alignment should be OK ........FC427......
waynos
ive been worried i could be runnin torry stubs,as my car handles like a tractor.
how much does the castor angle difference matter,you reckon?
It's camber angle that is different. Most noticeable during cornering as tyre contact on the road is not right. It's not hard to get HQ stubs - and they lower the car another 5/8ths of an inch.
jasonr70002
Can I get rotors for the hq set up to still run early stud pattern or do i need torrie calipers etc.
Hoppers Stoppers will sell you new HQ rotors that have been drilled in early stud pattern. Not cheap though.
jasonr70002
Ken how does that go for wheel selection and clearance can I still use 13's
No you will need to change to 14 inch rims. Basically with 13 inch rims you have the choice of HR discs or Torana discs. So if you use the Torana stub axles you just have to get the best alignment you can and see how it performs.
I have spoken in the past about lowering the mounting point of the HR upper wishbone. This does compensate and improve handling as well.
jasonr70002
Ken, What about HK, T, G  stubs and brakes as I have this option available to me are they a better option being the same stud pattern etc and then I can at least have the same whels on the car being 14"s all round.
Jason
HKTG stubs are the same as HQ stubs, so you can run brakes from HK to HZ all on the same stub axle
