fe indicators
Started by Utemad, June 04, 2009, 08:01:06 AM
Utemad
Hi people,
I am after a set of front indicators for an fe - can anybody help with a decent set?
Thanks Brent. :)
NosFEratu
Hi Brett
Just a thought - if you want to keep the non-indicator commercial look to your FE ute have you thought about getting some little "hot rod" indicators and mount them inside the outer edges of your grille.
That way you still comply with the need to have them but you still retain the commercial look to your car and you only really see them when they are on.
We did this with the van and we're very happy with both the look and functionality.
Kathi
NosFEratu
Utemad
Hey Kathi,
Never thought to put them there. Thanks for the great idea
Cheers brent
Utemad
Kathy, another question - what did you use on the steering column for the stalk?
NosFEratu
Hi Brent
Sorry, can't help you out there as our van is modified and has an FB/EK column fitted - so - can't give you any bright ideas on that one!  :-\
Kathi
NosFEratu
Brent,
You could always use an FE or FC special column, these had indicators fitted from standard and would give you the stock appearance in the car if that is what you are looking for
F4+ ;)
NosFEratu
Yeah, well no bright ideas other than that Keith - I just figured that was a given!  :-[  :)
NosFEratu
I have complete indicator set up for the column available - Also check out pics of my car on the Vic site - it is a standard model with indicators hidden in the grille. This keeps it looking like a standard from the front.
My car is white with a blue upper body and tilli flash kit.
You should find it no problems.
Utemad
Thanks Ken, I will take you up on the indicator setup, let me know how much and payment details.
Cheers, Brent ;D
