MOUNTING FE BONNET EMBLEM
Started by snuff69, March 10, 2009, 07:07:07 PM
snuff69
Hi everyone the bonnet I am using on my FE is a FC BONNET  so I need to weld up the holes for the HOLDEN lettering and mount the FE trim and badge.I want to put it in the right place so if someone could give me some measurements from the front edge of the bonnet to the bottom of the chrome trim at the middle I think that should do the trick.     THANKS DAVE
Rabbitoh
search FE Hood Ornament in Accessory of the week section
Fortius Quo Fidelius 1966; Saints' 2nd in 2027?
Bunnies' 22nd in 2027?
Hey Dave
The section Rabbitoh is refering to is a club member only section and not able to be viewed by all.
The measurement you are asking about is 26mm.
If someone has a spare bonnet without emblem, it might be useful to give the measurements to the holes instead.
snuff69
THANKS ALEX yeah if someone doeas have those measurements it would be a big help.   DAVE
Jonno
Hi Dave,
I have one in the shed that I can measure tomorrow it you don't get any other responses beforehand.
Jonno
Cottles Bridge, VIC
snuff69
Jonno
well...my trip to the shed wasn't entirely successful.  The measurements are shown below but it seems that, on this car at least (which I had thought was largely original), the emblem is mounted too low. On my ute (which isn't here right now for me to look at) the emblem is definitely higher, more like the 26mm Alex referred to.
So, it might be best to check another car or three first but then, maybe just add the appropriate amount (16mm?) to the vertical measurements below.  This diagram should at least give you the relative positions of the holes.  Note the 2 central ones seem to go through the bonnet and the bracing below so it might be 'interesting' to get that lined up nicely.
Jonno
Cottles Bridge, VIC
snuff69
THANKS ALOT JONNO we'll see how we go    DAVE
I measured a stock bonnet and centre holes are 61mm and outer are 52mm. This pretty much ties in with what has been written so far.
itb
Hi Dave'
I've got 3 FE bonnets. The emblem is 26mm up from the bonnet edge on all of them.
3 out of 3 ain't bad! Is that what Meatloaf said?
ITB
snuff69
