front guard rubbers
Started by vanessa, October 28, 2008, 10:16:02 AM
vanessa
can you buy the rubbers that go between front guard & pillar & front guard to top of eng.bay?   eg had guard of want to put back on with rubbers
Vanessa the rubber that goes between the guard and the front pillar was originalley part of the door rubber the re pro rubber do not have this and you will have to glue in a thin strip of rubber there for a replacement , as for the top edge it was just bolted down with a sealing compound between the faces ....Butyl Mastic should do the trick ......FC427....
vanessa
There was an antisqueak rubber between the fender and the pillar (part # 7409621 & 7409622) and also one between the fender and the grille (part # 7410013 & 7410014). At the very point of the inner guard at the rear there was a big blob of sealer which filled up a gap between the body, the skirt & the fender. It's rare to find these rubbers on cars unless the guard has never been pulled off in its life. Even rarer for people to put put them back on a resto or a rod. Their purpose as the name suggests was to stop body squeaks, but modern sealants do just as good a job. Nobody makes these rubbers as a repro and they are almost always dry and hard when removed. I have made replacements from U shaped rubber section in the past for my cars, but I would only do this if you were REALLY fussy.
