RE FITTING FC SPECIAL MOULDING
Started by FCOV6, September 29, 2008, 01:27:57 PM
FCOV6
Shortly i will be re fitting all that loveley stainless trim to bring out that shine its been missing for a long time, i want to help prevent any future rust problems so was wondering what should i use to replace the putty that was originally used ? I'm not keen on just fitting it back on with the metal clips straight onto nice paint.
FCOV6.
Only some of the clips had putty in the back - the ones which left an access hole for water through the door.
If this applies to any of your new clips I would use a dab of silastic to seal up the hole.
FCOV6 I use Wurth Dab off sealer for this job works great around the tail lights etc and is not messy ....FC427.....
