FC wheel cylinders
Started by Penguin, August 31, 2008, 09:48:54 PM
Penguin
I need to replace the wheel cylinders on my FC, original brakes. I found I can purchase EH wheel cylinders considerably cheaper than FC units. Is it possible to fit the eh cylinders to fc brakes?
Thanks in advance, Ben.
Papa Smurf
Would say no without other modifications as front FX - EK cylinder bore is 1-3/16 inch where as the EJ - EH are 1 inch & rear FB - EK are 1 inch & EJ - HR 13/16 inch.
Best check with a brake repairer as your brakes play a very important part in stopping a vehilce.
Papa Smurf
Quoterear FB - EK are 1 inch & EJ - HR 13/16 inch
What I should of said was rear FX - FC 1 1/16 inch & EJ - HR 13/16 inch
Penguin
I958GM
Dont know if this helps, but l have a complete rear end with near new cylinders, brakes,machined drums, axles and diff for $150.00 just taken out of my FC if your interested.
