steering box
Started by rod67, June 18, 2008, 08:09:00 PM
rod67
  ;)i brought  a cross member on e bay already set up for red 6 it doe's not have the mounts for rack and pionion if i am running HQ setup What steering coloum do i run rod
When you say you are running a HQ setup - what exactly do you mean. HQ brakes, HQ steering or what. Why would you want the hassle to run rack & pinion if you are only running a 6 cylinder engine?
I'm sure I don't understand the question!
rod67
sorry i met HQ stubs ,disks  calipers / what steering column and steering arms sorryagain for the confusion rod :P
julius
Hi
In my maroon FC I had run HQ setup ( brakes and stubs) I used HR ball joint steering arms and at the same time put in an EH column, they are 4 inches shorter which got the wheel away from me however one of the support bolt holes is a fraction out so run a drill through it and you need to make a spacing bush between the rail or pack with washers, you will see what I mean if you go this way.
All worked well and simple to do.
Julius
