repro FE weathershield fitment
Started by Rabbitoh, March 14, 2008, 08:59:24 AM
Rabbitoh
Tried to fit my new w/shield (Auto Shades sourced) and found that the top of the unit clashes with the little metal water deflector attached to the top of the quarter vent window frame. What is the better fix, cut a slot in the perspex shield, or the metal deflector?
Fortius Quo Fidelius 1966; Saints' 2nd in 2027?
Bunnies' 22nd in 2027?
Cut the plastic. Even some brands of genuine weathershields had a small notch cut in them
Just to add to Ken's it is always a good idea to drill a small hole and cut your notch to the hole will minimise the chance of a fracture  .....FC427.........
Rabbitoh
Gentlemen, you are both champions! Just what I needed to know. :D
fe1957
Quote from: Rabbitoh on March 15, 2008, 02:50:55 PM
When drilling perspex etc best use a blunt drill bit as sharp ones tend to fracture.
Grant
OFE570
Rabbitoh
Used an angle grinder with a masonry disc- just like a hot knife through the proverbial condiment.... :D
