brake booster dual cuircuit
Started by paddyfc58, November 12, 2007, 07:49:21 PM
paddyfc58
hi, with a hr front(disc) and rear end is it possible to use later model booster and set up a dual circuit, if so what boosters would be appropriate. if anyone could help it would be appreciated.
thanks paddy
reddo
Hi Paddy
My FC Panno has dual circ brakes. It is running a stock HK booster and dual master.
It clears the bonnet hinge oK.
Reddo
Hi Paddy I have fitted a VH V8 Commodore in my ute it also clears the bonnet hinge and the clutch master cylinder and very easy to find my had been recondition I pulled it off a car at the wreckers and cost $40 FC427
