Straight cuts
Started by srevoice, May 03, 2007, 05:46:13 AM
srevoice
Hello all, has anyone got some straight cuts for a grey they want to sell. I am doing up a hot grey and want it to make a bit of noise.
Andrew G
TAYZ
SRE, they dony have cuts for a grey mate, Ive asked myself in a earlier post!!!!!!!!  Only for reds
                                                               tayz
What about Diecrest Engineering?
Worth a try I guess, they make(made?) straight cuts for Red motors.
TAYZ
Whats there details Glenn, Im positive I did give them a try mid last year and the answer was no.
        tayz
Bagshaw St Harcourt VIC 3453
p: (03) 5474 2321
If they don't make them already, I am sure they could for the right amount cash.
srevoice
Thanks TAYZ and stinky, just my luck that they dont do it unless special ordered.
fe-ute56
try berco in act he will know ask for danny cheers
fccool59
never knew diecrest did that kind of stuff, thats the address and name of the ebay seller i got my thermo fans from @ about $27 each.
 when they say specail order does that mean they want a few orders in to get them done?, should i put straight cuts in the grey in my cabin cruiser?
TAYZ
i have made some enquires, this is a definately a no goer.  I have heard that a steel set is the go for the old grey and thats what I think i will get as mine has the shitty fibre one and im not driving to Mt Gambier and stripping it, cheers >:( >:( >:( >:( :P :P
                                                             tayz
Quoteas mine has the shitty fibre one and im not driving to Mt Gambier and stripping it
There's nothing really wrong with fibre ones in general, as long as they're kept lubricated.  If the oiler to them gets clogged up (often the case in a car that has sat for a long time), they get brittle and collapse.
Note also that it's a designed weak-point, because it's a lot easier to replace than a lot of other engine internals. It can be replaced without pulling the engine out.
Having said all that, if you've souped up the engine a bit - cam, double valve springs and the like - you'll be putting more stress on the timing gear than they were really designed for, so a steel one is probably a good idea.
Hope that's some help.
fccool59
maybe fibre timing gears are ok, but after striping two within six weeks on the F3 freeway i personally am too scared to get on the freeway again with fibre gears.
TAYZ
Mine has the cam and valve springs etsc etc, no bloody fibre for me.....!!!!!!!!! ;D ;D
