Rear engine mounts
Started by TAYZ, September 25, 2006, 09:45:30 AM
TAYZ
I have purchased a trimatic conversion kit to put in my FC.  Today FE HOTROD and myself masde an attempt to install it.  The template that bolts to the trimatic bellhousing is different to the FC engine mounts so did EK Hydromatics have different rear engine mounts to manuals as the template is made to fit EK Hydromatics??  If so does any one have any laying around........
                                                      tays
earlyholdenfan
I would have sworn they were the same, I am up in Reservoir and have my kit out of the car at the moment, do you want me to drop round after work and compare the two???
Matt
TAYZ
If you feel like driving to ballarat!!!!!
earlyholdenfan
What about if you shoot me some piccies to
earlyholdenfan  AT  iinet  DOT  net  DOT  au
and I will send you some of mine, then if we cant work it out photgraphically, I will come for a drive on the weekend! could use an excuse to check out the Tayz mobile!
Matt
Tays - EK rear mounts are deifnately different to FC rear mounts.  The EK ones are about 5 mm taller than FC.  You wouldn't think it would make any difference but I tried to fit EK rear mounts to an FC and they wont fit.
I guess EK trimatic and manual rear mounts are the same.
fe hotrod
 ;)tayz just got off the phone to young Chips and he reakons that ek auto mounts are different to manual ones!!and to do your conversion you will need ek-ej hydramatic engine mount plates!!!anyone got some??cheers jamie ;)
