WIRING HARNESS ??
Started by FATBOY, July 20, 2006, 04:29:34 AM
FATBOY
who makes complete harnesses for utes mine having the following running gear vq statseman injected 5 litre with matching turbo 700 auto.
cheers fatboy
fatboy
0414712441
smithy
hi fatboy, give glen a call from airride technologies http://www.airide.com.au/
he can supply you with a harness to suit whatever applications you need just let them know what you intend to run. i used one of his kits and found it of high quality and quite easy to install.
Ed and a couple of other forum members have also used one of his harnesses.
dean
Hey Fat,
id also recommend you get the motor and ECU loom
relay and fuse panel too if you dont have them already.
i used a mix of V6 and V8 stuff, it's all the same and then the air ride kit was for the body wiring.
would you believe you can drive your V8 on a V6 chip as well.
