186/202sump
Started by Phantom, May 11, 2006, 02:41:08 AM
Phantom
G'day all, do the 186 and 202 (reds) have the same shape sumps?
                     Cheers Rusty
Bogans rule
Sump varies a bit depending on what vehicle it was fitted into, eg Torana and Kingswood sumps aren't the same.  For fitting into an FE or FC, you want the EH sump shape.
Hope that helps.
Phantom
This 202 is out of a lx ? Torana, will i have to swap sumps over from my 186? and is the oil pickup the same in all reds?
                               Cheers Rusty
Bogans rule
Hey Rusty.
You need the EH sump and pickup. If the 186 is in your FC now, you need to use that 1 as it would probably be the EH version.
The pickups are also different for each sump as they are shaped to pick up the oil from the lowest part of the pan.
Phantom
Thanks for the info blokes
                                   Cheers Rusty
Bogans rule
Phantom
Are the pickups interchangable between 186 and 202 motors?
                                    Cheers rusty
Bogans rule
Again, it depends what the motor came out of.
The design of the pickup needs to suit the sump, and the shape of the sump is determined by the steering and cross-member of the vehicle.
That's why people generally sell them as a pair.  To put a red in an FE or FC, you need the EH sump and pickup.  I have heard there is a particular Torana configuration that also fits, but I'm not sure which, and it might only suit R&P steering setups.
Phantom
Ret i have a 186 in my girl now , i am swapping the 186 for a  202 that came out of a LX torrie , i am swapping the sumps over will the pickup from the 186 fit the 202 motor?
                                      Cheers phantom
Bogans rule
My bad, sorry.  Yes they are.
In NSW these days if you go over 200ci (even those 2 more cubes) you need collapsible steering column and assorted other mods.  That's why Geoff_K pulled the 202 out and put a 186 in to register his modified FE (BAY-255) for the Nats.
You don't have that rule in Vic, presumably.
