FC SEDAN. Parts car Only.
Started by slim, April 20, 2006, 09:39:47 PM
slim
I have an FC sedan parts car for sale . Not Restorable ( as far as Im concerned). It has the following parts. Original FC engine . Engine # 8-L 400429.  Still on engine accessories. , Head, Tappet assembly, exhaust manifold, thermo housing ,fan, harmonic balancer,, starter motor, generator, water pump. It also has the Flywheel , Clutch , Pressure plate and thrustrace bearing. Complete Original gearbox assembly with All linkages , slave cylinder, Tailshaft. Also has Original Kingpin frontend with all steering components. Still actually steers and Rolls. Has Original Fc rear end also.. Other items  include full accelerator setup from pedal to carby. Steering column (bare), bonnet hinges, Front and rear windscreens , Rear complete with good chrome moulding, Clutch pedal assembly,Handbrake assembly. Front and rear special seats in blue and black. Back section unripped,Front top section only needs restitch. Unripped original spiral pattern hoodlining, panic straps, high beam switch, door hinges and door mechanisms, Good fuel tank and heaps more. I want $200 for it . Take it away. Also has 4 standard fc rims on it. In Liverpool NSW . Ring SLIM 0401303998 or if interested in any parts will seperate.
Im located at Liverpool, NSW
