NOS SILLS
Started by FATBOY, October 23, 2005, 08:10:05 AM
FATBOY
are nos sills all the same length do they fit all models ???
cheers fatboy
fatboy
0414712441
Seems a strange question fatboy, as your definition of "all models" could be taken quite literally.  I assume you mean just the early model Holdens?
Basically FX and FJ are individual
FE to EK are all the same
EJ and EH are the same
HD and HR are the same.
There is no chance of making anything outside this range try and fit.  You would be better off starting with flat steel ;D
FATBOY
#2
seeing as where supposed to stay on fe fc topic i was refering to station sedan ,panelvan ,sedan  ute sills????
cheers fatboy
fatboy
0414712441
nicko
#3
Yes and no they are same length but different as i have one that has all the shapes for a wagon or sedan BUT you can just cut out the part that goes into the rear door opening if you have a van or ute as it still goes up where door frame is ,so yes they are different but very useable if you cant get the exact one .
this is a wagon/sedan nos sill i have and you see the rear wheel arch and rear door opening in pic you just cut out the door section and bobs your uncle.
cheers Nicko
OK, my apologies.  Nicko is quite correct - the ute and van sills are different at the rear.  They are pretty rare to find NOS
though, most are sedan/wagon sills
You can use the sedan/wagon sills in utes and vans, but not the other way round as Nicko has pointed out.
