little heater brand new
Started by heateracman, October 04, 2005, 11:35:04 PM
heateracman
BARGAIN BRAND NEW
UNDER DASH HEATER
TO SUIT HOT ROD, 4WD OR OTHER AUTOMOTIVE application
THE UNIT IS NEW
THE CASING IS PLASTIC AND HAS BOTH HEATER  CORE  INSIDE UNIT
HEATER CORE IS ALUMINUM WITH 16 MM OUTLETS
OVERALL dimension are as below
HEATER AIR CONDITION       Specs
Dimensions      250 MM X 190 MM X 110 MM
Volts      12
      $160.00 plus gst
The unit has a twin blower wheels with a two speed  12v motor
This unit side mounts
Any other questions please email me
I have photos of the unit
Can email to you
NOTICE: TRADE & WHOLESALER WELCOME
 www.geocities.com/radiatorexpert/
heateracman
#1
here are some pictures of the unit
you will need these parts  below
I have 5 pole 3speed switches with knob for $18.95 (this small unit is 2 speed),  Bosch 30A 12v mini relay $8.50, 30A circuit breaker $10.50, 57mm heater ducting $10.20 per metre, demister funnels $24.50 ea.
HEATER TAP $30.00 EA
HEATER CABLE $ 30.00 EA Â
