Fitting venitians
Started by Paul-FcWag, June 28, 2004, 11:20:34 PM
Paul-FcWag
 Hi all
I was contemplating buying venetians for the rear sides of my wagon and was wanting a few opinions about them. both positive and negative would be great
How are they fitted? do they clip on about the window or do you need to fit them in under the roof?
Do they bend to match the shape of the window or do they just hang straight down? id imagine they may look a little out of place if they dont match the shape of the window???
any opinions- and especially advice on fitting them would be appreciated.
Hello,
my venetians (when fitted) will slide in under the rubber seal.
they follow the windows quite closely (not sure about the repros tho).
and I reckon they look great.
earlyholdenfan
I personally have found "Smooth's" venetians to be first rate repro's
He charges around $350.00 for a set of three, or $250.00 for just the side two!   :)
they match the original pretty well and follow and window contours and line well, the upright's sit under the window rubber and can be fitted and removed in seconds!
Matt
P.S. check out the venetians on earlyholdens.com where they have pictures of original and repro together to see the differences and similarities!
Jodstar
Hi Thumper, Just fitted a full set of repo's from Rare's
a few days ago. I had no problems fitting them and
they look great! You won't regret it :D :D
        Jodstar
