Commodore diffs
Started by Paul, May 24, 2004, 08:03:10 AM
Paul
I have an VP SS diff. I was told.... Instead of shortening the diff, I should use a VL diff, and put the center, discs and brakes on the VL housing. Aparently the VL has a very  similiar track width as the FC (using VL rims) Is this the case?
sgo
I think ther are a few different widths from vb-vc-vk etc.
but a vb(?) used here just fits.
The gaurds had been previously pumped out a bit so I'm not sure about fit for a dead stock body. I'm in the process of resetting rims to gain an extra 10ml per side.
Pabs
is that diff a Borg wagner or a sailsbury?
Sarge
Paul I fitted VN disc brake rear end. I was told that a VL was an easyer conversion, but I went with the VN for the strength. Which ever you use you have to have it modified.
SGO is that a HQ tank your useing and was it much trouble fitting as I am thinking of doing the same.
Sarge
       0421 165 351
Digger
Hi Sarge,
With the convertion on the VL diff do you know if it had to be shortened or dose it fit with deeper ofset rims.
Im running HR diff but wont to go with the Crapadoor stud patern.
thanks
steve
smithy
hi digger, im using a VH diff which i gave to a shop to get cut down, as the 195/50 tyres which were on there were scrubbing on the outside of the guards, these were mounted on standard chaser rims. as i wanted to run wider tyres, the shop cut the diff down to HR specs, the problem now is that the tyres have minimal clearance on the inside due to standard wheel offset, so im having the offset changed now to suit.
i have just found a similar clearance problem with the front now that i changed over to commodore front discs.
ah the joy of it all!
sgo thats some fine tank work
dean
Digger
G'Day smithy,
Thanks for the reply Dean, it never ends ya seem to modify one thing and you have to correct other bits.$$$$$$.
Thanks again,
Steve
sgo
The tank is a stock VP sedan one and is an easy fit. Though you do lose the stock spare wheel well and the filler is set up to exit through the drivers side quarter panel!
Burnsy
Have you got anymore pics of the tank setup from inside the boot maybe?  Have you re routed the filler to the standard location or gone with the quarter panel location? Does the standard VP sender unit match up to the original fuel gauge?
Mike
Burnsy
SGO, found the other pics of your tank on your website, nice fit!  Did you investigate moving the filler point on the tank?  Just considering whether it is a worthwhile option as I need a new tank but would like to keep the rear filler and don't have a spare $700 at the moment for streetneats repro's.
Mike
Mike
Sarge
Steve
I have never done the VL conversiobn, But have been told that this is the way to go, as there is no need to have it shortened.
Sarge
       0421 165 351
Digger
Thanks heaps Sarge, I have a VL diff that was given to me so I guess this weekend I will be doing some mathmatics.
It would be nice to fit the panhard rod, stabiliser bar and coil springs and such but thats to big a job.
Thanks again,
Steve
Digger
SGO,
Do you know if the VP diff center is the same as the VL.
VL: Borg Warner 78 series (Salisbury type)
Thanks,
Steve
Sarge
Steve
Your very right when you say keeping the panhard rod, stabiliser bar and coil springs it is a big job. My elder brother has just finished doing this to his EH wagon. He cut the floor out of the EH and the Commodore (VP). Then welded the complete VP floor into the EH from the firewall back to the rear bumper bar. Now he is starting the front as he wants to try fitting the struts (good luck I say).
Sarge
       0421 165 351
Digger
Sarge,
Boy your brother must be a gluten for punishment !!!  :o
But I gues it would be the best way to go and lots of luck to him, dammed if I would go that far.
Steve
sgo
I really didn't look at moving the filler on the VP tank, but if you did it without blowing yourself up it should work out ok? There is thread on welding fuel tanks in here somewhere?
As for the diff i don't know about the centres but the VB V8 one I used had the right ratio of 3.08 for the V6.
Just a thought, are vk-vl a bigger body so do they have a wider rear end than vb-vc? This is just an impression I've picked up but haven't really checked it out!
Digger
#16
Thanks for the reply SGO,
The only thing I know is the body widths IE:
Fe : 1701mm
FC : 1702mm
EH : 1727mm
HR : 1778mm
VK : 1722mm
VL : 1722mm
VN : 1794mm
VB : 1722mm
so I think that the diff length of the cars must be very close.
Steve
It has been done.  This EJ was at the ACT AHD a couple of years ago.  Very impressive.
Digger
Very nice ret, very nice,
I would like to see the convertion, and take a ride.!!
Steve.
FC-V8
Hi all
       When doing the Borg wagner conversion in my wagon I had to keep the wheel track fairly wide as the rear calipers go very close to the leaf springs plus you need to allow for extra movement of the caliper as the pads wear.
Glenn
0401-065-201
