proportionong valve
Started by Phantom, May 11, 2004, 07:29:08 PM
Phantom
G'day all,
                Does anyone out there know if a HQ proportioning valve will work with my HR disc front end and a FC drum rear end , will it help the dreaded rear end lock up?                      Cheers Rusty
Bogans rule
Digger
#1
Hi there Rusty,
The HQ proportioning valve (Limiting Valve ) will work fine.
You can also change the rear wheel cylinder size to a larger bore and will have the same efect.
PBR have a 9/16ths wheel cylinder that will bolt in and you wont need the proportioning valve.
One thing Rusty have you a HR rear drum set up for disk or the standard HR set up and are you boosting the hole brake set up or just the front disks.
Steve.
ACE
Phantom,
Have a look at page 2 in this section with the heading
"Rear Brake Cylinders"!!!!!!!!!!
This should help answer your questions. ;)
Regards ACE 8)
