FC wagon , RESTORE OR parts car !!!!!!
Started by slim, February 18, 2004, 05:40:43 AM
slim
FOR SALE . FC wagon. Or STATION SEDAN . Has rust but will restore, Is ideal parts car., All 4 doors, Good bonnet, ,Absolutely Rust free Tailgate. All Glass. Front and rear seats. Some stainless moulds,  rear bumper, Fuel tank, bonnet hinges, Master cylinders and slave cylinder, , 2 Good Radiators, Steering column  , 4 standard rims, all tailgate supports both upper and lower, has  rust free battery box... Lotsa other parts not mentioned . Has to go .. Council on my Back again,, $400.the lot..... Ring Slim 0402465768 in Liverpool NSW. WAGON HAS NO GUARDS.
Im located at Liverpool, NSW
slim
If your restoring a wagon , there is lotsa parts on this car . It has an especially good Rear Tailgate set  (upper and Lower .
Fast_Eddie
Slim,
What's the subframe like, or do you still have the FE one available?
slim
Yes the fe one is still kicking about the joint. The one in this wagon seems good , But they all do until you pull em out ... No really it looks quite good , except the front has had a whole cut in it for some reason, nothing a welder and  steel wont fix...
Fast_Eddie
Slim,
It could be for a fresh air intake for a heater if it is in the radiator shroud on the near side. I have had a car with that set up in the past.
I've got an FC that might need a sub frame. Is the FE one spot on?
Out of interest, how is the FE chassis number identified on the chassis number, is it numerals only, or prefixed by "FE"?
slim
Yes its SPOTON , I actually cannot believe it hasnt been snapped up . The Number on the inner gaurd is 7.11120B....
normd
Hey Slim
    Wasn't Cat after a fuel tank , or did she get one ?
 see if she want's the tank for $550 & the rest of the car for FREE  ;D
    Norm  :)
slim
YEAH , I thought about that , And shes quite welcome to come and pull it out . Or stand next to me whilst I lay on the ground and do it for hER . !!!!!..
Ed,
In answer to your question about chassis numbers, all FEs and FCs until the second week of December 1958 had the last digit of their assembly year stamped on the chassis number (6, 7 or 8).  From then on all had "FC".
Fast_Eddie
Thanks RET.
I once put an EJ subframe on an EH shell, and then had a drawn out debate with an RTA inspector when it went over the pits as to its identity. I didn't want to make the same mistake twice.
I can refer them to the firewall if I end up using a FE subframe. I realise it is not original, but neither will be the 307 Chev!
Edward
slim
#10
FC WAGON is Going to a RESTORER.    Hence it has been SOLD.
