What is the right size bolt..
Started by Laszlo, June 08, 2021, 09:22:11 PM
Laszlo
.... for a boot emblem  ?
In the bolt and nut shop they tried to tell me I need a 12/24. Wasn't the right one. I did try a metric 4, not too bad but not perfect. A little bit loose.  Maybe just the age of the emblem and a rechroming.....
Thanks : Laszlo
Sent from my SM-G965F using Tapatalk
Holden = The Heartbeat of Australia
Stewy
Parts book says :  SCREW round head. cross recess No. 10-24 x 1/2" with lock washer x2
Cheers Stewy   8)
Laszlo
Thanks Stewy !
That was quick.
Laszlo
check to see if somewhere in its life the thread hasn't been damaged or brutalised to make something fit ,or clogged with chrome ,carefully use a 24TPI tap to clean up...cheers Vern
Laszlo
Thanks Vern I will try that way.
I started to change all the bolts ,screws and nuts for stainless steel one. So if someone  has to take the Fe a part 60 years time no rusty surprises..... : )
Cheers  : Laszlo
Laszlo,
3/16" Whitworth is also 24 TPI.  OK, so the thread profile's slightly different, but it will substitute for 10-24 UNC no problem.
Laszlo
Thanks Rob !
I did find some 10-24UNC stainless steel 304 or the good stuff 316 at Anzor
