Cams FC Resto
Started by camxsmith, August 15, 2015, 10:00:05 PM
Ol_Girl_58
Does the grille badge come with mounting brackets?
camxsmith
Quote from: Ol_Girl_58 on January 29, 2021, 06:08:53 PM
It does come with the bracket. The one thing if its not a metal shell its plastic with what looks like a chrome paint. Mine has a couple of small imperfections that are had to find. But other wise its looks great. And for the price I found it hard to go past.
JOX515
More great work Cam, this car will come up a treat when done. Good buy with the brill badge too.
Cheers, Graeme
camxsmith
Nearly finished..  just a little more cleanup to go
I do have a question ???? ...  Does the small angle piece that holds the door seal, does it continue all the way to the door sill plate. See the gap in the picture below..  I have a feeling I have cut it off...
Cam,
Short answer - yes.  The weatherseal retainer continues all the way to the scuff plate.
The retainer goes just until the 45-degree section of the scuff plate, which is where the dogleg/inner wheel arch steps down to be level with the sill.  That's odd.  Your scuff plate is cut square at the rear.  Maybe this is another Special/Standard difference.
Cam ..My Special FC sedan,rear seal , yes the seal channel goes up to and under the scuff plate about an inch ,and the scuff plate is arrow head in shape ,yours looks to be cut off square ,and that observation is supported by your windlacing tunnel looking a bit short ..I have followed your resto with interest , your a gifted bloke doing excellent work ,along with many others on here ...keep well Vern .
Rod
Hi Cam,
I had a look at mine. Drivers side goes up to 7-8mm prior to the scuff plate, while the passenger side is approximately level (1mm). This area is unmolested on mine but maybe more so due to when the sills were replaced many moons ago and the scuff plates aren't entirely centred when the holes were redrilled.
I like the grill badge. I was unaware that there was repro's. Thanks for sharing.
Cheers Rod
camxsmith
Thanks for all the replies guy much appreciated, really do enjoy this forum and the people whom use it ....  I do hope when Im posting that other enjoy, even if its just a little.  ;D
My journey has not fished so more to come..  ;)
camxsmith
I now finished both left and right ends of the sills , I also add a little more metal to the front of the guards, made them hang down just a little bit more
Next the inner guard, already have my piece cut to finish the inner guard
camxsmith
Ok inner guard welded in just got to clean it up
also picked up some repo scratch plates, and like the grill badge look really nice.
I do have a question on the original or repo scratch plates ...  do they wear away at the door paint over time???????.    and has any one put something behind them to stop the movement ?
Longman
Are they the plates from rotary products? Good value at $149 for a set of 4. Can't wait to see your car done.
Yes they are good. Put a pair on my ute recently and didn’t put anything behind but was thinking some mastic would be the go.
The originals don’t wear away the paint from my experience. I think it depends on how good the fit is from the repro. If it contacts the paint smoothly it won’t be a problem
Mine weren’t a perfect fit I’ll say that. Sit proud slightly at the bottoms if I recall.
camxsmith
Got busy and made 3/4 of my chassis strengthening bars, will make the rest once front k frame is on.
First crush tubes front and rear
Made clearance for rear foot wells
Then repeat, and you have two.
Longman
Nice work Cam, just did the same on mine.
camxsmith
Final patch for the floor now going in. Now that the crush bolts are done for the chassis strengthening..  Have some sort of celebration for completing the floor.. ;D
Rod
Great work Cam. I am enjoying your journey.
I look forward in seeing her around in all its glory.
Have a ripper. Cheers Rod
Longman
Congratulations on finishing the floor, it's a great feeling!
camxsmith
Just some more rust being removed
Cut out and rust treated, and weld thru primer
Weld in metal
Grind, sand and paint
