Boot Separater Board and Firewall Board
Started by oldgrey58, March 09, 2021, 10:45:07 PM
oldgrey58
Hi all,
i'm seeking advice as to what others have done to replace or rejuvenate the fibre board that goes at the back of the boot behind the rear seat and the (what looks like to me) heavy cardboard used under the dash on the firewall.
Can these be retreated to get the waxy look and colour back?
Or are there replacements available?
Also, where can you get those metal serrated clips that hold the cardboard to the firewall?
Thanks in advance.
A trimmer should be able to source the board for the firewall and behind the rear seat.
I have plenty of the original clips in my collection of stuff. I’ll look them up.
oldgrey58
Thank you again Ken.
Also, would anyone recommend a trimmer? I'd prefer Melbourne south east suburbs if possible but not essential.
TIA
For the firewall insulator, go to Martin Frigo (Classic Gloveboxes?).  He might be able to do the rear seat partition too.
oldgrey58
Apparently Classic Gloveboxes are no more unfortunately.
I've been doing a web search with no luck and found a previous post that confirmed they are MIA
http://forum.fefcholden.club/index.php?topic=21426.new
In that post there is a link to an ebay site that is still active that sells repo firewall boards at $500.
https://www.ebay.com.au/itm/NEW-AUSTRALIAN-MADE-FRONT-FIREWALL-INSULATION-PANEL-BOARD-SUITS-FE-FC-HOLDEN-/151777973202?hash=item2356ac13d2
I'm still to track down a trimmer so any suggestions are welcome.
Billy Blackarrow
I just used 3 mm ply painted black  ;D ;D ;D
BILLY BLACKARROW
I used2.5mm thick black plastic mining sheet ,came from mining supplies at Lithgow ,strong rigid sheet,laid it flat with some weights ,went over it with hot air gun,it remained flat as it comes in a roll ,cut shape with disc in angle grinder using timber guide ,made holes with wad punch ,very happy ..Vern
You can get trim board from Daleys who are in most states, this is the closest material to original that I have found and use it for door trims, glovebox liners and boot boards.
I contacted Classic Gloveboxes a couple of years ago expressing interest in their firewall board patterns as I heard they were winding up, they told me they still going and that is the last I heard.
oldgrey58
Martin Frigo, that is Obsolete Rubber Co. Daleys or your local trimmer should be able to help though.
oldgrey58
Hi Errol - thank you, I'll give them a call.
KFV888
james at classic automotive products in pakenham melbourne makes all the kick panels, firewall insulation, back boards and seat belt reconditioning, truly a magician and a master at his art
