Rear Camshaft seal in block
Started by Wookie 66, August 03, 2020, 07:39:38 AM
Wookie 66
Hi all
I have removed the camshaft seal from the rear of the block when replacing the welsh plugs and I don’t think I was suppose to
This seal I’m guessing is not part of the welsh plug kit is it ?
Non of the kit seem fit
Any assistances would be appreciated
Wookie 66
Forgot to mention it’s a grey 138 fb or ek motor I think
Trevor,
The camshaft welch plug is shorter than a regular one.  Last time I rebuilt a grey motor the engine shop machined a welch plug down to suit.  If you can get access to a lathe, it shouldn't be too hard. (Or a belt linisher?)
Measure the bore diameter to the nearest 1/32" to give the size of the plug you need.
Wookie 66
Thanks Rob
The welsh plug kit I got I used the bigger ones that fitted the correct holes
The rest are to small
From what your saying I’ll have source anther larger one and linish it to fit or get one made
Rabbitoh
1 3/8" is the camshaft plug diameter. Depth is as per the rest of the welch plugs.
Fortius Quo Fidelius 1966; Saints' 2nd in 2027?
Bunnies' 22nd in 2027?
