Outer EK Wiper Arms
Started by FStech, May 16, 2020, 06:11:55 PM
FStech
Hi Guys,
Couple of Wiper Arm Questions
Will EK Outer wiper arms and blades fit on my FC (straight swap)? If this is possible it will make it easier to purchase new blades.
I understand there are 2 types of EK outer Wiper Arms Vacuum and Electric, if they fit which ones do I get (and whats the difference)?
Also what wiper blades do you guys buy when fitting new blades to original FC Wiper Arms? I cant seem to find them listed anywhere.
Thank you in advance.
Steve
The only difference between FE FC and FB EK is in the way that the blade carriers attach to the outer arms. So while the components are slightly different, they are interchangeable as a set. They take the same inserts so no point in changing from that perspective.
FStech
Thanks for the reply Errol, Ill run with the latter and keep what I have grabbing some new inserts.
Steve
