Fe Fc sedan venetian - different to ute?
Started by texmorton, October 31, 2019, 10:22:17 AM
texmorton
G'day,
I have an original venetian blind out of an FC ute, question is are the blinds different shape / dimensions for sedans? Or are they interchagable? I assume they are different but seems to roughly fit an FE rear glass I have. If somebody can help me out that would be great. Also, I assume FE through to EK utes rear glass was the same so should fit all four models? thanks in advance. Al
Sedan venetians are different to Ute venetians and attach differently as well. Utes have screws into the divider while sedans attach under the rubber or sit on a little support bar at the bottom.
FE FC Ute venetians are in fact different to FB EK Ute venetians.
texmorton
Right oh, thanks Ken. I should have just messaged you eh. Al
Dr_Terry
In addition to what Ken has said, the rear glass on FB/EK utes is actually different to FE/FC utes.
Dr Terry
collecta
Only the two curved pieces are different size, centre same on all ute models.
Dr_Terry
Quote from: collecta on November 09, 2019, 10:43:43 PM
Yes, I've found that too, but why is the part number different for the centre glass between FE/FC & FB/EK ? The difference must only be minor.
Dr Terry
old-blu
Because they are slightly different sizes. I had a few centre glasses of each before I downloaded & they are not the same. I found this out " the hard way" after stripping out an FB Ute paddock wreck hoping it would fit my FE Ute. [no luck with that one].
6th, may 1958 "I was there".
