Newbie here my fc
Started by The holden man, April 22, 2019, 11:20:34 AM
The holden man
Hi guys, names adam,new member to the forum but have looked up info here in the past, have been playing around with old holdens (mostly fe-fc and hk-t-g)since i was a teenager (37  now) i work for an engine builder in the albury/wodonga area and have a soft spot for hot greys will post some photos up of my toys, i have a 59-1/2 fc special which is going for its second rwc test tomorrow, and we managed to squeeze 130rwhp out of the old fc L block, it is pretty cranky and piggy to drive but wouldnt have it any other  way
Also have an fe panel van that was my paddock basher as a kid, just lucky i never wrecked it, its fitted with a 383 sbc and commodore 6spd but still going through th conversion process
The holden man
#1
The holden man
#2
The holden man
#3
The holden man
JOX515
The holden man
camxsmith
Looks great well done ..  hope you don’t mind a re posted a couple of images.. ;D
The holden man
All good, thanks for doing that, took me a bit to get that imgur app worked out ;D
Very nice and stock looking. I bet a different impression comes across when you turn the key.
The holden man
Sure does, with a 2-1/2" exhaust and pretty big cam, a crow regrind, marty put a humpy holden speedway gring on it,
Its actually an old repco sports engine +.060 so .185" oversize from standard fc block, still running the repco pistons,
We took .030 of the block to zero deck it then about .080" off the head i ported out to get the comp upto 9.5:1,
186 valves
Double race springs to suit a series 1 v6 commodore
The holden man
Had to make up custom pushrods to suit using 265 hemi pushrods with the grey pushrod tip machined down and inserted then silver soldered, slant 6 full flow oil fiter setup drilled and tapped into the block, made 130rwhp at about 6000rpm but was starting to pull vaccum so triples should see more power
2brite
a video with the grey on song would be nice to see.
go the mighty grey
So effectively a 138 plus 60 thou, for 149cui. Hi comp. Good breathing. Not so powerful to stress bottom end and drive train. Bit of an adventure to drive. Sounds like a good way to go. You’re not lazy like me and put in a red motor.
Clay
The holden man
Next time i put it on the dyno at work i'll get a vid, and yeah worked out to 149ci with the 3.185"-3-3/16 bore, took about 7kg out of the flywheel to, would be heaps better with a four speed but i kind of like the column shift nostalgia, my fe van on the other hand should be a weapon with the alloy headed 383, tr6060 6spd and torana front end
Yes yhe old nostalgia box should stand up to it if you don’t hammer it. You only need syncro in city driving. So I keep telling myself as I don’t want to cut the floor in mine.
The holden man
https://i.imgur.com/yqbaZdv.gifv
Hi guys, hopefully this works, was the first dyno run of the fc from a couple months ago before we tweeked the timing and carbs a lil further, only revving to 6000rpm should be good to 7000rpm but going to wait till it loosens up a bit to rev it that hard
Oh boy! Oh boy! Oh boy! Oh boy!
2brite
awesome looking sedan
any engine bay pics
The holden man
Thanks, there is one pic above, i'll try and get onto taking some more pics during the week, have got some of the buildup process pics i'll put up as well, these days im pretty pushed for spare time and need to sit down for a while to juggle the pics to imgur then onto here
