132 grey motor oil
Started by bryan, April 07, 2002, 07:20:17 PM
bryan
HI there can someone tell me what oil i should use in the 132 grey motor? :)
PeteR
Bryan,
Oils are one of those 'horses for courses' things.  However with the older motors, ie red and grey motors, the best oils seem to be the 20W-50 varieties, not the Kmart reconstituted stuff, but from known companies, eg Castrol, Mobil, Shell etc.  Really you can't go wrong, especially if you change at the recommended intervals, 6000 miles if I remember rightly!!
Peter
craiga
Bryan,
Try asking the oil companies. They all have Technical departments who would be more than happy to help.
TRY
//www.shell.com.au
//www.valvoline.com.au
//www.castrol.com.au
Here is a list of Castrol oils including a description.
http://www.castrol.com.au/castrol_001/products/pd_engoil_index.html
I have already sent an email to Valvoline so I'll let you know the response.
Craig.
bryan
Thanks guys for your help with the oil,a big help. :)
craiga
Hi Bryan,
Heres the answer from Valvoline. It also may be of assistance to other grey motor owners.
"The original GMH specification was API SD 10w/30.  As you can appreciate, there has been some changes since then.  I would recommend you use an API SF monograde 30 engine oil such as our Super HPO 30."
See http://www.eposode.com/fc%20test/1033.pdf for product details.
You will need the Acrobat viewer installed. You can get it for free from http://www.adobe.com/products/acrobat/readstep.html if necessary.
Craig.
FCwagon
If you use a single grade oil you should be matching it with leaded petrol. As this is no longer available you should use a good multigrade and change it every 1,000 miles.
Red & white is alright
