Firewall section
Started by kma, May 19, 2009, 10:00:23 AM
kma
Firewall section wanted from the drivers side about 12 inches square with the center being the brake and clutch master cylinder's bolt holes.
Regards Kevin
NascoHunter
Hi Kevin,
The Vic club have had these made. You can buy it complete or sections. Ring John Warren 0411316137 or 9873 3909 email john@classicgloveboxes.com
Tony.
Rabbitoh
Hi Kevin and Tony,
I think you may be talking about different things :-\.
Tony means that the (internal, cardboard/hessian backing) firewall insulation panels have been repro.ed, while Kevin may be talking about needing a section of the actual steel firewall panel?
If I'm wrong, just forget I spoke :-[.
R.
Fortius Quo Fidelius 1966; Saints' 2nd in 2027?
Bunnies' 22nd in 2027?
Trevor_B
Hey Kev,
You might want to check out the FC sedan shell at Centre Rd Wreckers in Springvale.
They have a fairly stripped shell and I think that part of the firewall is there.
The challenge is to get it - perhaps try calling them and see if they will cut it out for you (them are a self service place).
Check out their website here: http://www.autowreckers.com.au/Home/Home.asp
Trevor_B
kma
Hi Guy's,
Thanks for the replies. I will be checking out that wrecker.
Regards Kevin
Rabbitoh
Just checked him myself, they said they had nothing???
Trevor_B
Hmm, it was still there about 2 weeks ago, stuck between a HD & a HK Wagon.
If you can wait until Saturday I can go down there and check if it's still there.
A check on Google maps shows it was there about 12 months ago - type in: "centre road wreckers clayton vic" ;D It's a bit above the centre of the main yard, parked close to vertical in the image (the left hand row) between 2 diagonal rows of cars. Look for white roof & green bonnet, no boot, below a white ute... can you find it??
More likely they didn't know what an FC was  ;)
Trevor_B
If you can't get anything in Vic send me a PM and I'll check my wrecks.
kma
Hi Trevor,
That would be great,
Hi Stinky,
Thanks for the offer. I will see if Trevor can find the FC.
Trevor_B
Hi Kev,
FC is still at Centre Rd Wreckers in Clayton:
They will cut it out for you but would not give me a price - busy on weekends... so you would have to talk to them during the week. My guess is that they would not be cheap so maybe stinky may be a better option particularly as you are on the other side of Melbourne.
Rabbitoh, was your interst in the sub frame?? If so, it is rusted on left hand side however right side is good.
Ken, No ID plate but chassis No is 82875M.
Regards,
Trevor_B
Quote from: Trevor_B on May 23, 2009, 02:32:58 PM
Are you saying I am cheap?  :P ;D
And easy too.... ;D ;D ;D
jack_fc
nasty, as well...   ;D ;D ;D
kma
Thanks Trev for your time spent checking that out.  :) :)
I should have enough equipment to remove that section, only need access for towing a generator in.
Plan A: Phone them Monday and cut it out on Wednesday.
Plan B: Check out Stinky's bargins.  ;D ;D
Cheers Kevin
Trevor_B
They are putting words into my mouth Stinky ;D, perhaps I should have said a bit more realistic??
Self Service Wreckers are a funny breed - most want to charge you the same price regardless of the age, condition or true value of a part - these guys are usually quite good but if you want them to do something then it's expensive.
Trevor_B
Rabbitoh
Regards,
Trevor_B
Hi Trevor,
I need the front half floor pan from sill to sill (left to right), and from centreline of front seat to a few inches up from base of firewall (back to front).
Our van looks like Fred Flintstone's ride at present .
Thanks,
R.
zakmicheal89
I have bought couple of FC from wrecky car wreckers. https://www.wrecky.com.au/car-wreckers/
wreckeroo
If you are unable to find anything in Vic then you can find here https://www.wreckeroo.com.au/
