Clutch slave cylinder bolts
Started by DJ, February 16, 2017, 11:57:23 AM
Does anyone have the dimensions of these mounting bolts?
I need to buy a couple the correct length & can't find reference to them.
DJ,
By memory - bolt head, spring washer, engine mount bracket, gearbox case, slave cylinder bosses, internal tooth lockwasher, nut, protrusion of bolt.
So: 1/16" + 3/32" + 5/8" + 1/2" + 1/32" + 3/8" + 1/8" = 52/32" = 1-5/8".
Try 3/8" UNC x 1-1/2", threaded all the way as a first guess.
They may be closer to 2" long, though.
Well thought out Rob, just looked it up in the parts book and its 1 3/4 long!
