Aluminium Radiators
Started by CoolFCWgn, June 25, 2014, 09:57:39 PM
CoolFCWgn
Airfireman
Gday Ian
Did you purchase this Radiator??????
If so can you recommend??
Tim
Trevor_B
Hi Tim,
I purchased one of these (can't tell if exactly the same as link now does not work).
It was certainly not  the same as the original radiator and presented significant difficulties in attempting to fit it into an FC.
I first tried it in our ute, due to the extra thickness it had less than 5mm from the fan and the top and bottom tanks fouled. The mounting holes were also out of place.
When I tried it in our sedan there was a little more clearance to the fan but only just enough... Same problem with fouling and mounting brackets. After some subtle modifications I have installed it in the sedan but certainly not happy with the result. Will stay until I can get an original one re-cored.
My advice would be to buy one only as a last resort and be prepared for challenges  :(
The Ebay vendor was prepared to take it back based on no damage and original packaging which is a bit hard as mine was vacuum plastic packed and of course as soon as you try to slide it into place you touch the fins against the radiator and so it looks damaged.
Trevor_B
Airfireman
Gday Trevor,
Thanks for the info,
I was deciding whether to re-core the original Rad or purchase new.
I never clicked the buy it now cheap ebay radiator as I suspected cheap will lead to problems.
Appreciated
Tim
ACT59FC
I just had my fuel tank repaired in a radiator shop. Whilst there I asked the exact same question. The guy told me that numerous people purchasing these alloy radiators have taken them back out and reinstalled the original. He said the Alloy ones in his experience don't cool as efficiently as the original and advised me to stick with the brass and copper.
Regards Rod.
FC Dave
I dont know if this applies to older cars, but we had a Aluminium Radiator fail on a VN calais due to water in the tail lights causing a crook earth & stray current.
Radiator bloke says it will attack rads & welsh plugs. Just something to be aware of maybe.
When i bought my PWR radiator it says to get a multimeter and put it into the coolant to make sure thee is no curent whatsoever.
http://www.pwr.com.au/wp-content/uploads/PWR-Notice-to-Owners.pdf
