Washer nozzle.
Started by NES304, April 19, 2016, 07:00:34 PM
Looking for a pair of screw in nozzles for windscreen.
Billy Blackarrow
Try Rang Rover I think they should fit That is if you are after the one's like EK
Billy B
BILLY BLACKARROW
Yeah I did see that. Just wondered if anyone had any...
Not original but OK if you are stuck ......
I purchased a pair in Jan 2014 from the seller below.
Cost then was $10/pr + $4 post. It looks like they are still operating.
Website: http://www.classicpickupsupplies.com.au
E-mail: classicpickupsupplies@yahoo.com.au
Phone: (07) 5446 2667.
Champion DJ thanks.
Not looking for original necessarily but noted some EKs had bonnet ones. I'm thinking that if the bottle is mounted in the bay with the  pump then the water lines stay in the bay too. There is zero room with the air con under the dash 😳
Will be interested in seeing your final solution.
JOX515
G'day NES, I ended up drilling the bonnet and putting the washer nozzle there, easy to run the line from the washer bottle to the nozzle that way, and no water inside the car....  Cheers, Graeme
Thanks Jox can you send a photo?
JOX515
Will do Marc, still at work so will do it in the morning.
