FREE - 5 speed gearbox conversion
Started by Longman, February 11, 2016, 12:02:32 PM
Longman
Hi. Just removed from an FC sedan. Complete conversion as follows:
- Sigma 5 speed gearbox with shifter
- Adapter plate for red motor
- Clutch and pressure plate
- Starter motor
- Slave cylinder
- Tailshaft with Banjo fitting
- Custom crossmember.
Gears select smoothly. I have not driven this box, so is a giveaway AS IS. Pickup Mount Hutton , Newcastle. No floor tunnel mods were made on my car to fit this other than hole for the shifter. Conversion was done in the 80's by Rod Hadfield. PM if interested. Need it gone ASAP.
Ill take it for my wagon as i do not want to cut the floor if its still available.
But would like to give u cash or grog
Crumpsnr
Might be a bit long and interfere with the bench Pete. I had one in a sedan years ago and I had to go to to buckets. Regards,
Martyn
Longman
Quote from: Crumpsnr on February 11, 2016, 10:13:41 PM
Martyn
Thanks martyn ill check it out.
Im currently doing commodore 6sp shifter relocation set ups for a fella so may be able to move the shifter on this one
